I read in another thread Using the Finder (or other file explorer) with Obsidian files? Problems? that filenames can’t be renamed from the file system because links wont auto update.
I wanted to use a couple of Hazel rules that periodically rename some filenames, since these filenames are changed from outside Obsidian the links wont auto update.
Is there any way to do this? Workaround?
Thank you in advance!
