Brand new to Obsidian - loving it so far - so much info/sharing in the online community!
Simple question - when brackets are auto-paired, what is the key that completes it? If I hit enter, it goes to the next line, if I hit tab, it indents. Down-arrow works and it is cumbersome - is that changeable and/or is there a different key combination that works?
I don’t think there is a command to bind a hotkey to — you’re just moving the cursor the same way you would anywhere else in the text.
You could turn off bracket auto-pairing to see if it’s less annoying to just type the closing brackets yourself. That’s what I normally do, for that reason (in Obsidian I’ve left it on so I can delete brackets more easily when I accidentally make a link).
