Create new note.
Start a code block using ```
Move cursor inside code block to write code.
Writing * or _ at this point will autocomplete the second * or _, as if you are trying to do markdown. But you’re not since this is a code block.
Shouldn’t get markdown autocomplete behavior in code block.
Auto-pairing happens
Windows 10
- Debug info:
Obsidian version: v0.13.14
Installer version: v0.12.19
Legacy editor: off
Base theme: light
Safe mode: on
