Hello,
This bug as been discussed on the following thread:
To sum up: auto pair markdown code syntax does not work with Keyboard set on language other than US on MacOs.
Could you please fix this bug, this feature is so usefull.
Thank you.
Hello,
Thank you.
Please follow the bug report template.
To reproduce this bug install a keyboard like the Norwegian or French layout, and do the following:
, and needing to hit the space bar
before the backtick appearsSYSTEM INFO:
Obsidian version: v1.5.3
Installer version: v1.5.3
Operating system: Darwin Kernel Version 18.7.0: Tue Jun 22 19:37:08 PDT 2021; root:xnu-4903.278.70~1/RELEASE_X86_64 18.7.0
I’ve got multiple keyboards installed on my MacOS, and when I switch to another keyboard which doesn’t have the backtick (or grave accent) as a dead key, I immediately get the expected result.
I’ve now searched a little related to this, and according to About the backtick on a French Mac keyboard, you can seemingly install a tool called Ukulele and do some magic to make it not be a dead-key.
I’ve not yet installed it, and I’m not sure how to actually type stuff using the dead key if you do the modifications as suggested. I’ll come back to you with more information if I get around to installing it.
