Auto-pair bracket/quote nesting
When taking notes for classes I sometimes put quotes inside a pair of parentheses. I’ve noticed that quotes don’t auto-pair within parentheses or brackets, which slows my note-taking somewhat. Parentheses and brackets auto-pair within quotes so I’m not sure why it doesn’t work in reverse.
Allow quotes to auto-pair within maybe not brackets but parentheses at least? I realise this may be a coding situation but I’m not clear on how that affects quote pairing.
Honestly mostly just dealing with it (typing the second quotation mark myself) or shifting the quote to a tab-in instead? Still messes with my flow.
Quotation marks do auto-pair within parenthesis and brackets.
They don’t autopair when the cursor is beside a character, regardless of whether you’re typing inside parenthesis.
In the examples below, the 🚀 represents the location of the cursor. Obsidian automatically adds two quotation marks when you type " at these locations:
a 🚀
(a 🚀 )
(Note the spaces.) Obsidian does not auto-pair at these locations:
a🚀
🚀b
(a 🚀)
(Note the lack of spaces around the cursor.)
The way to use this in practice isn’t seamless but might help a little. While in parentheses or brackets, you could type a space, press the left arrow (to separate the cursor from the closing parenthesis character), and then type ". That will create the auto-pair. But of course, now you have an extra space you may or may not eventually want.
that would explain it! thank you for the help
