I am a therapist and use Obsidian for importing annotations from articles and books. Most of my readings include APA-style references within the paragraph, such as:
- (Ben-Levy, 2023)
- (Ben-Levy & Johnson, 2014)
- (Ben-Levy, 2023; Ben-Levy & Johnson, 2014; Terrance et al., 1992)
I like to use those references to create new notes, such as
- ([[Ben-Levy, 2023]])
It allows me to find all of the references to that article throughout my vault before reading it. Once I read the article and annotate it, I will import it into Obsidian and use the following naming convention:
- @Ben-Levy_2023
- Property - alias: Ben-Levy, 2023
I would like to know if there is a tool or script that is available that will look through a new imported annotated note from Zotero and automatically add the link so that I don’t have to go through each one adding [[ ]] multiple times. I don’t need the actual note created, but just the [[ ]].
I’m a therapist and not proficient at coding or script creation. I’m curious about that process, but I’m hoping for help as this is far outside my wheelhouse. I used An Academic Workflow as my guide to setting up Zotero/Obsidian.
Below is an example of an annotation before any formatting that I might do within Obsidian:
- Two potentially relevant factors could be coping self-efficacy (CSE) and emotion dysregulation.
- CSE is the perceived ability to navigate stressful environmental posttraumatic demands (Benight & Bandura, 2004).
- Emotion dysregulation is a dynamic construct consisting of a lack of emotional awareness, understanding, and acceptance combined with an inability to manage or tolerate emotional distress (Gratz & Roemer, 2004).
- CSE tends to serve a protective role against negative posttraumatic sequelae including PTSD symptoms (e.g., Mahoney et al., 2019) and frequency and consequences of substance use (e.g., Dolan et al., 2008;Hayaki et al., 2011 ;Warren et al., 2007).
Thank you!
