Auto-generated daily note prompts
I’m no coder (I’m older than the Internet itself), so I’m not sure if this is possible.
I’m having a hard time becoming interested in a Daily Notes habit and I’m guessing that it has something to do with staring at a blank page. Now, I know that I can build a note template in Templater, but even after a few days of seeing the same questions in the template, I get bored.
So, here’s my solution (if it’s possible):
How It Could Work Conceptually
  1. Template Trigger
  • You have a note template (using Templater or core templates) that you call “Daily Journal,” “Project Brief,” etc.
  • When you create a new note from that template, the custom plugin intercepts the creation event (or runs immediately after) and modifies the resulting note in some way.
  1. AI-Generated Questions
  • The plugin calls an external AI API (e.g., OpenAI) to generate context/topic-specific questions.
  • It embeds these AI-generated questions into the newly created note as headings (H1, H2, etc.).
  1. Final Output
  • The user sees a new note that includes the static content from the template (whatever fields or prompts you already include) plus automatically generated questions that the user can answer.
I’m picturing in the plugin settings the user can input a list of topics that they are interested in for the LLM to draw inspiration from in the formation of new daily notes questions.
Every new daily note would have interesting conversation starter questions for me to journal on. Almost like daily notes meets fill-in-the-answer flashcard type questions.
I would always have something new to trigger my writing that I would be interested in and every day would be slightly different because of the Ai new question embeds.
Here are examples that would fit my settings input:
Morning Prompts
  • What strategic planning goal do I want to achieve today?
  • How can organizational design improve my current workflow?
  • What change management strategy should I focus on today?
  • What consulting challenge can I tackle today?
  • How can I optimize my online marketing funnel today?
  • What aspect of PKM do I want to enhance today?
  • How can I improve my note-taking techniques today?
  • What organizational development initiative can I start today?
Insights & Learnings
  • What key takeaways did I have about strategic planning today?
  • How did organizational design principles influence my work today?
  • What change management successes or challenges did I encounter today?
  • What consulting insights did I gain today?
  • How effective were my online marketing strategies today?
  • What PKM techniques worked well today?
  • How did my note-taking improve today?
  • What organizational development progress did I make today?
Questions & Curiosities
  • What unanswered questions do I have about strategic planning?
  • How can I further explore organizational design in my projects?
  • What aspects of change management are still unclear to me?
  • What consulting methods can I experiment with next time?
  • How can I refine my online marketing funnels for better lead capture?
  • What new PKM strategies can I implement?
  • How can I make my note-taking more efficient?
  • What organizational development goals should I set next?
Connections & Ideas
  • How does today’s strategic planning align with my long-term goals?
  • In what ways did organizational design impact my team’s performance?
  • What change management techniques can I integrate into my workflow?
  • How can today’s consulting experiences inform my future projects?
  • What correlations did I find between online marketing and lead capture?
  • How can PKM enhance my understanding of strategic planning?
  • What improvements can I make to my note-taking process?
  • How can organizational development contribute to my company’s growth?
I’ve moved this post from Share & Showcase Plugin Ideas, and renamed it to a title that describes the plugin (was “Is this plugin idea even possible?”).
While not precisely what you’re asking for, the plugins “Prompt” or “Daily Prompt” might be of use to you. You could also look at the Dice Roller plugin to select prompts from lists or files.
Thank you for that. New here, so I appreciate the direction.
Interesting. Let me take a look at those plugins. Thank you for taking the time to comment and help.
