Auto-capitalize is enabled in code blocks
  • Create a code block with three backticks
  • Start typing
Y
I expect code blocks to display what I type without any form of autocorrection or automatic capitalization. Code tends to be case-sensitive, and automatic capitalization interferes more than it helps.
The first letter of every line is automatically capitalized. This makes it annoyingly difficult to write valid code.
Operating system: ios 17.1.1 (Apple iPad)
Obsidian version: 1.4.16 (114)
API version: v1.4.16
Legacy editor: off
it’s the apple keyboard that autocatalyzes. Not sure if we have control over it, but you can open a FR for this.
As an app developer, you absolutely do have control over the keyboard behavior.
Ok, open a FR for this. Thanks!
