Audio stops, while scrolling
  1. Play audio file in bigger document
  2. Scroll down quicker
  1. Document will scroll while audio is playing
  1. Document will scroll but audio will stop playing
  • Operating system: Mac Os
  • Obsidian version: 0.9.9.1
+1 on this bug
Macos 10.12.6
Obsidian: 0.9.15
I have the same problem.
macOS Ventura 13.1
Obsidian v1.1.12
2023 - I am still experiencing this issue. I troubleshot to see if it was a certain element while scrolling down the page, but didn’t see anything I thought would cause an issue…
The same problem (audio stops to play when scrolling approximately two screen hights) in Obsidian v1.6.7 under Windows 10 Home, version 22H2, build 19045.4651
I think it is because the mp3 component has been removed from UI since it is out-of-render-distance.
+1 This is really annoying and it happens with youtube videos also.
The problem still persists, and I’m using v1.9.8.
Workaround: split a note to the right or down. Use one note to play the audio and the other to scroll the note.
Has this bug really not been fixed for six years? What could be the reason? Is it possible to solve the problem by installing a plugin?
Having the same issue as well.
