Audio Record Hotkey
First of all, I LOVE Obsidian. So much so I’d like to make it slightly better. :grin:
So, I create audio memos on a daily basis. As someone who has a limited Hotkey budget (lots of plugins and limited memory), it would be a nice hotkey saver to use the same hotkey to start and stop (toggle) the recording.
And unfortunately this doesn’t work:
:cry:
My proposed solution is to create a new hotkey option to Toggle the Audio Record with a single hotkey. :joy: Something like “Audio recorder: Toggle recording audio”
The only workaround that I can think of is to have a key combination modifier, something like Ctrl+R (on) and Ctrl+Shift+R (off). :neutral_face:
This is a problem for me as well. On mobile it requires two separate buttons in the toolbar to perform the functionality of the single start/stop recording button on desktop
Came here to say this as well. In addition to “limited hotkey budget”, it’s just easier to remember one hotkey instead of two.
Using CodeScript ToolKit to do this:
Toggle audio recording (for use with hotkeys and stuff) - Share & showcase - Obsidian Forum
