I’m using Obsidian to store and play a library of audio files. I’m a Parkinon’s sufferer with a hand tremor and I’m finding it tricky to tap the small controls on the audio player for play, pause, etc on an iPad. Is there any way at all to make the audio player and its controls larger? I’ve tried css but that doesn’t appear possible.
I had a look around and was able to change the desktop controls a bit. There are ~18 audio::-webkit-media-controls you can play with as well as the width/height of the player.
But, on mobile, the player comes from iOS/iPadOS it seems.
I didn’t see a way to change that at all with CSS. Running the desktop mobile emulation wasn’t useful here.
If I come across anything, I’ll let you know.
