- Use BT Keyboard on Android.
- Add Properties
Ctrl
- Try to move from Properties to note content, by ussing
DownArrow
key.
Yes
Move cursor from Properties to note content.
Cursor don’t move.
The opposite works.
I can move from note content to properties, by using UpArrow
key.
Operating system: android 9 (HTC HTC U12+)
Obsidian version: 1.4.16 (114)
API version: v1.4.16
Legacy editor: off
Snippets enabled: 2
Plugins installed: 17
Plugins enabled: 10
1: Calendar v1.5.10
2: Kanban v1.5.3
3: Find and replace in selection v1.0.1
4: Extended MathJax v0.4.1
5: Editor Syntax Highlight v0.1.3
6: Dataview v0.5.64
7: DB Folder v3.5.0
8: DataLoom v8.13.2
9: Iconize v2.8.0
10: Metadata Menu v0.6.11
Additional info
Workaround: use Esc
key.
