Applying cssClasses to note
I’d like to apply some css to a specific note.
This snippet works, but applies it to all notes when they’re in preview mode.
.markdown-reading-view .markdown-preview-sizer,
.block-language-dataview.node-insert-event, .block-language-dataviewjs.node-insert-event {
  width: 100% !important;
  max-width: 100% !important;
.markdown-reading-view .markdown-preview-sizer>div>*:not(table) {
  margin-left: auto;
  margin-right: auto;
  min-width: var(--file-line-width);
  max-width: var(--file-line-width);
.markdown-preview-sizer>div>table {
  width: 100%;
  margin-top: 1em;
  margin-bottom: 1em;
But even after including
obsidianUIMode: preview
cssClasses: my-table
as the frontmatter in my goal note, the following does nothing:
.my-table.markdown-reading-view .my-table.markdown-preview-sizer,
.my-table.block-language-dataview.node-insert-event, .my-table.block-language-dataviewjs.node-insert-event {
.my-table.markdown-reading-view .my-table.markdown-preview-sizer>div>*:not(table) {
  margin-left: auto;
  margin-right: auto;
.my-table.markdown-preview-sizer>div>table {
  width: 100%;
  margin-top: 1em;
  margin-bottom: 1em;
Any advice?
thanks
CssClasses are set on markdown-preview-view (or markdown-source-view), so if you flip around the first part, that should take care of it. e.g.
.markdown-preview-view.my-table :is(.markdown-preview-sizer,
    .block-language-dataviewjs.node-insert-event) {
.markdown-preview-view.my-table .markdown-preview-sizer>div>*:not(table) {
    margin-left: auto;
    margin-right: auto;
.markdown-preview-view.my-table .markdown-preview-sizer>div>table {
    width: 100%;
    margin-top: 1em;
    margin-bottom: 1em;
In this case, this is also an option and seems to do the trick:
.my-table :is(.markdown-preview-view .markdown-preview-sizer,
.block-language-dataview.node-insert-event, .block-language-dataviewjs.node-insert-event) {
.my-table :is(.markdown-preview-view .markdown-preview-sizer>div>*:not(table)) {
  margin-left: auto;
  margin-right: auto;
.my-table :is(.markdown-preview-view .markdown-preview-sizer>div>table) {
  width: 100%;
  margin-top: 1em;
  margin-bottom: 1em;
Awesome, thank you!
