Apply set theory to tags (hyperonyms) : linked tags
I think tags are realy usefull, it’s like virtual note to categorize “reel” note.
So tag are concept, note are content.
But there is a problem : a concept can be included by a more fundamental concept : this is called a Hyperonym in linguistic.
I have some notes specific to #religion (for exemple), so I tag it.
But I have some other note about #belief. It’s not directly about religion, but religion has a hyperonym : “belief”.
So if I search (by search or graph) all notes about belief, all notes just taged #religion will NOT appear !
You can tell me : I just need to add #belief in note talking about religion… but it’s a bad structuring.
Imagine I put note about #christianity and another #islam etc… if for each note, and for each concept/category/tag I have to write all hypernym tag… it will be long, heavy and boring…
I think it will be a verry verry good new feature to add hyperonym link for tag.
It’s exactly same as link between note, but its for tag only
And now, when we display graph or research, we can add an option “depth hyperonym” (or “depth tag” for more common understanding) to get all notes included in childs concept.
EXEMPLE :
with this structure :
  • #belief => #religion => ( #christianity | #islam )
if I search #belief with
  • depth = 0 : (it’s the current system) get only notes with #belief
  • depth = 1 : get all notes with #belief AND #religion, but NOT #christianity or #islam
  • depth = 2 : get all notes with all this tags : #belief #religion #christianity #islam
what about this idea ? :slight_smile:
Like nested tags?
Cool idea! To take the provided example, with nested tags you might create #religion/belief. But also you might want #belief and/or perhaps, within another context #emotions/belief.
I think there is definitely something to be said for a feature that would automatically return all notes tagged with the word belief occurring at any level in the nested tag structure. This can be accomplished using regex searches with Obsidian native search or Dataview queries (see links below). That being said, if there were something like a “wildcard” mode for the Tags core plugin, that automatically did this, it would make life a lot easier and nested tags more flexible.
Related: Dataview regex query to match all occurrences of a subtag
Also related: Searching for sub-tag
Thanks!
I do not use nested tag because nested tags are not tag in search system… (or I don’t understand how it works?) :
if i have #test/test2 and I search #test2, it will not appear… so I dont understand the utility to this system, because It need to know and to type all expression (#my/super/expression/could/be/long) to find my notes… AND to write it in each new note… (ok there is autocompete, but it’s takes a lots of place for nothing)
If I talking about #labrador why do you have to write #animal/dog/labrador it’s not realy “readable friendly” ^^
And more, if I discover, after long time, there is an intermediate level : I have to rename EACH #test/testX to #test/new_intermediate_level/testX
I think it’s not resilient ! I think it’s better to define structure in metadata for exemple, at only one place. If there is a changement, there is only one place to update.
(sry for my english, I hope you understand my arguments :slight_smile: )
PS : nested tag are not linkind on graph too… it’s a fault for me, it’s could be better to see link between tag itself.
Wow, you’re right! I thought you might have literally searched #test2 instead of tag:test2 or tag:#test2, but those don’t work either. (I don’t use nested tags, as you can see. :sweat_smile:)
(Also, your English is clear enough!)
Not what the OP wants, but as an adjunct to the point about searching nested tags, a simple quotes-restricted search is pretty effective:
"/test2"
As an adjunct to the adjunct :stuck_out_tongue:, the tag: operator uses Obsidian’s tag index and so should be faster. But the regular search is pretty fast, so it may not matter unless you have many notes or are very pressed for time.
Also tag: matches tags in YAML frontmatter. With /test2 the plain search will do it, but with #test it won’t because frontmatter tags don’t use #.
Adjunct to the adjunct to the adjunct, or something like that, it’s possible to use the line: in combination with other stuff to match related to parts of nested tags:
But it’s more than anything proving that it might be interesting to take another look at how to use tags and how to search for tags related to each other.
This is what I get if I repeat each #tag and #parentTag in each notes :
We have to know and write “OR” reasearch to get it…
now with neasted tag :
we can get just using #belief BUT, there are all disconected…
What I suggest/need to get :
Connexion beetween tags is clearer… no ?
I’m not sure if I understand the problem or hyperonyms, but I stole a solution from Roam research and made my concept “tags” pages. So [[+belief]] instead of #belief. I tag [[+belief]] with a #tag tag and group that to show a different color on the graph. Plus I add the “+” prefix to distinguish tags from the notes with content
Then you can link your “tags” together.
sry I realy understand nothing ^^ can you take an exemple?
if you see my screen, I dont understand how cant understand what i said ^^
nothing new about this idea? how suggest directly to dev ?
No new plugin or update about the possibility to link tags? :cry:
Hello,
Thank you for creating this topic and then bumping it – reading the thread prompted me to think some thoughts I otherwise wouldn’t have, and I’m very glad that I did. So, thanks!
I have some suggestions for the feature request. Sorry in advance if I haven’t properly understood what you were suggesting.
1 – Suggestion to simplify the wording of the feature request
I think the mention of set theory and hypernymy makes the suggestion sound unnecessarily technical and complicated. As I understand it, you are proposing a plugin to grant the ability to create and manipulate hierarchical relationships between searchable terms. If you agree with me that this is accurate, and more likely to be understood by others, then you might consider renaming the thread as something like: “plugin to represent conceptual hierarchies among search terms”
2 – Suggestion to broaden the use of the function beyond being restricted to tags
I see no good reason to limit the proposed functionality to tags. I think the functionality should work globally across all search terms, with users given the option to apply it to tags. So, if I search “religion”, the plugin will offer to return files tagged with ‘Islam’, and also files containing the word ‘Islam’. (Perhaps I could configure the plugin so that it only looks at tags – though I don’t see why anyone would want that).
As an example of why it’d be better not to restrict the functionality to tags: you might have some notes that mention Islam, but that are not tagged with Islam. If the plugin works globally, you’ll be able to build connections among those notes without having to go back and add that tag.
3 – Suggestion to broaden the range of relationships beyond just the generic-specific (hypernym-hyponym)
I see no need to restrict the hierarchical relationships to hypernym-hyponym relations (e.g., religion-Islam); you might want to represent other hierarchical relations, such as the relation of being a part of a whole (e.g., religion is part of culture, and of society, and of identity). Thus, I think the plugin should offer the function of marking a search term as either the parent or the child of another term, with the option to specify the nature of that relationship if needed. Perhaps there could also be an option to mark two terms as siblings – this could be useful if you wanted to mark two terms as being connected, without one being the parent of the other, and without having to spell out the nature of the connection (for example, suppose a detective has an intuitive sense that there is a connection between ‘mysterious substance oozing from the victim’s purse’ and ‘something off about the foreman’s alibi’; in that case, while it would be logical to create a parent term to cover them both – ‘strange aspects of the grizzly murders at the docks that seem connected but not in a way I know how to articulate’ – it might not be helpful or desirable). There could also be a third type of connection – cousin – which would occur if two terms share the same parent, but do not share the same type of relation to that parent. So, ‘Islam’ and ‘Christianity’ would be siblings, because they would share the same relationship (‘type-of’) with their parent, ‘religion’. On the other hand, ‘sacrificial ritual’ would also have ‘religion’ as its parent, but with a ‘part-of’ relationship, rather than a ‘type-of’ relationship; thus, ‘sacrificial ritual’ would be a cousin of ‘Islam’ and ‘Christianity’.
This is sounding a bit complicated. But, the core of what I’m suggesting is the ability to specify either a parent-child relation between search terms, or a sibling-sibling relation between them, and the ability to add a label for the nature of the connection (e.g., type-of, part-of). Thus, when I search “religion”, the plugin will return some results marked as “types of” religion (e.g., Islam, Christianity), and others marked as “parts of” religion (sacrificial rituals, prayer, Christmas); and others marked as “is part of” (e.g., culture, society, identity).
I’d like to heartily endorse this concept! Or at least, what I think OP is getting at, which is a sort of automatic inference from subtags to all tag paths ending in that subtag.
So, if you have #Math/Linear-Algebra and #Math/Numerical-Analysis and #CS/Numerical-Analysis, and you want to put a page Gauss-Seidel Iteration under all three tags, you could just type the tags #Numerical-Analysis and #Linear-Algebra, and have the rest filled out automatically, because the system knows that each category is necessarily a subset of its containing categories.
Notably, this implementation is just a kind of autocomplete at the time of writing, meaning the final source of truth is still the markdown files, which iirc is an important principle for the team.
So I didn’t think I’d be asking for something this “complicated” even though it’s fine by me, but yes, there are other types of hierarchy.
The concept can indeed be generalized to create whatever hierarchies and tree structures we want. But the main idea was really to use tags to connect concepts.
If in every note we have to define metadata that indicates the hierarchy, it’s redundant and tedious.
Whereas putting that in the concept itself, with a card linked to the concept using tags, seems more relevant to me: we create concepts, we link them however we want in terms of hierarchy, and then our notes are linked to the concepts through tags.
For me, it’s not only about research, it’s a reel categorization :wink:
