Any easy way to produce pure text /ascii based diagrams readable in source mode?
I would like to keep my notes readable in source mode as pure text. But i have problem with diagram charts and such.
For now i use this ASCIIFlow but it would have been much easier if there was editor inside Obsidian.
Example of text based diagram:
|      Diagram box      |
   |                       Something
   |                        happens
 +-v--------------------+       |
 |     Diagram box 2    |            |
  • searched all around the web for plugin, if it exists i can’t find it
Is there any way i could use something like ASCIIFlow directly inside Obsidian?
Gosh! I didnt know this even existed. It would have made my ASCII diagrams a lot easier to generate. I typically just create them manually inside a code block like this:-
                                     -->| SUBSCRIBER 1 |
                     -->| TOPIC A |---->| SUBSCRIBER 2 |
    | PUBLISHER 1 |---->| TOPIC B |---->| SUBSCRIBER 3 |
                     |       .       -->| SUBSCRIBER 4 |
                     -->| TOPIC Z |--|
                                     |->| SUBSCRIBER 5 |
                                     -->| SUBSCRIBER 6 | (interested in TOPIC Z subtopic A only)
I use mermaid diagrams as well and i have to create them in mermaid.live and then copy the text into a mermaid code block. I imagine you will need to do something similar for ASCII diagrams.
Glad it helps you :sweat_smile:
Yeah, i do copy paste them from ASCIIFlow to Obsidian.
But i already have an IDE, source of the information, Obsidian and multiple other windows open.
It would be nice to get this feature in the Obsidian to do less window switching.
Have you tried using an iframe?
<iframe src="https://asciiflow.com/#/" allow="fullscreen" allowfullscreen="" style="height:100%;width:100%; aspect-ratio: 16 / 9; "></iframe>
Nope it’s interesting though. It possibly bypasses a need for other plugins as well as long as there’s web service. I have to explore iframe bit more.
However i also need it to work offline. For offline workaround also found using “ASCII Art Studio v2.2.1 [Portable Edition]” to be relatively useful even though it lacks diagram specifics like lines with arrow “glued” to objects.
