I’m simply trying to type in my notes. Nothing special. But my cursor get’s lost all the time. This means, that while typing my key presses are suddenly not recognized anymore and the cursor is not in the text anymore as well. When this happens, the top border of the window flashes one time for a brief moment. To get back to typing, I then have to grab the mouse and click in the editor window again. This can happen quite often, like every few words or sentences and it completely messes up my flow of typing up to the point where it is not tolerable any,ore.
I am using Obsidian on several PCs and across Linux and Windows 11. My entire Vault including all plugins and all settings are synced by Obsidian Sync. What I don’t understand is that this happens only on my main PC under Windows 11. On the same PC on Linux and on at least three other PCs on Win11 this does not occur. Too bad, that the machine it happens on is my main PC that I use the most.
In an older post from like 2022, somebody solved a similar problem by disabling and then reenabling all plugins. I tried this but it did not change anything. I have also uninstalled and reinstalled obsidian but it did not help either. Also I have vim-mode disabled.
