Android Status and Navigation bar only adapts to theme color after changing Base color scheme
The navigation and the status bar on Android systems only adapt to the theme color after changing the Base color scheme in the settings.
  1. Select any theme or snippet that changes the background color of a note to anything other than pure black
  2. Change the Base color scheme in the appearance settings to “Light” and back to “Dark”
  3. The top and bottom of the app will match the theme, as expected
  4. Restart the Obsidian App
  5. The top and bottom of the app will be pure black
Yes
The navigation and the status bar should always match the theme color.
The navigation and the status bar always revert to pure black after the App is restarted.
	Operating system: android 15 (Google Pixel 6a)
	Obsidian version: 1.8.9 (195)
	API version: v1.8.9
	Catalyst license: none
	Community theme: Minimal v7.7.19
	Snippets enabled: 3
	Plugins installed: 15
	Plugins enabled: 14
		1: Smart Typography v1.0.18
		2: Minimal Theme Settings v8.1.1
		3: Reading Time v1.1.2
		4: Better Word Count v0.10.1
		5: Advanced Tables v0.22.1
		6: Better Command Palette v0.17.1
		7: Commander v0.5.2
		8: Highlightr v1.2.2
		9: Linter v1.28.0
		10: LanguageTool v1.0.14
		11: Style Settings v1.0.9
		12: Dataview v0.5.67
		13: Iconize v2.14.7
		14: cursor-goaway v1.3.0
This has been fixed in 1.9.0
