- Android 16 system settings, go to
System > Navigation modeand select3-button navigation. - In Obsidian, select the light color scheme.
- Observe that the white navigation buttons are blending in to the white background.
N/A. This is a rendering issue and none of the app settings fix it.
I would expect the navigation buttons to be visibly distinct from the background.
The buttons are not visibly distinct from the background. They can still be used if you know where to tap.
Obsidian version: 1.12.7 (303)
API version: 1.12.7
Operating system: Android 16 (Google Pixel 9 Pro)
Webview version: 147.0.7727.55
Catalyst license: none
Plugins installed: 2
Plugins enabled: 2
1: Excalidraw v2.5.0
2: Tasks v7.10.2
I’m following up on thread 103701, and you can find screenshots there.
On native Android, to switch to dark buttons when a light color scheme is in use, you can set WindowCompat.getInsetsController(window, window.decorView).isAppearanceLightNavigationBars = isObsidianColorSchemeLight whenever the color scheme changes.
If you don’t have a native Android hook for theme changes, I found some Capacitor-specific information in a tutorial named Android Bars. Looks like you’ll need a plugin.
