Android: Editing Toolbar appears but does not work when external keyboard is connected
Since some versions the editing toolbar (bold, italic, …) on the lower screen area isn’t working anymore - it doesn’t show up.
This happens consistently when having the Book Cover (Book Cover Keyboard Slim
EF-DX920) docked on my Galaxy Tab S10 Ultra. If undocked and using the on-screen keyboard, everything is fine. This has worked before, but I can’t remember the concrete app version.
doch the book cover so you’re using the external keyboard
yes
I expect the tool bar to appear in editing mode as it used to.
No editing toolbar at all if the book cover was docked when the app was started. If docked later, a non-functional toolbar is displayed on the lowest spot of the screen. But it’s dead.
Operating system: android 15 (samsung SM-X920)
Webview version: 140.0.7339.51
Obsidian version: 1.9.12 (237)
API version: v1.9.12
Catalyst license: none
Plugins installed: 3
Plugins enabled: 1
Are you able to add a screenshot or two of what it looks like with, and without the book cover docked?
Sure.
Book cover docked, then app started: no toolbar
Book cover undocked, on-screen keyboard: toolbar appeared and is working
Book cover re-docked: dead toolbar
Thanks, that is very helpful!
You’re welcome!
let me know if you still experience this problem when you get 1.9.13
Just FYI - still 1.9.12 in Play Store.
1.9.13+ is available to insiders, not to the general public.
1.9.14 is now available to public. Do you still have this issue?
sorry to report that I can’t see any change … :-/
Any update regarding this issue? Thanks.
@WhiteNoise Do we have any other reports of this?
No updates, aside from the fact that we a lot of BR around external KB and editing toolbar not working
I’d appreciate if I would been able to work with Obsidian on my Samsung tablet again … I mean it had worked before, so something broke, and now it’s become unproductive.
Please fix what you’ve broken, thanks.
The current version changed the behaviour a little bit, but the functionality is still broken.
  • Book cover docked, then app started: no toolbar
  • Book cover undocked, on-screen keyboard: toolbar appeared and is working
  • Book cover re-docked: no toolbar
Operating system: android 16 (samsung SM-X920)
Webview version: 141.0.7390.122
Obsidian version: 1.10.3 (251)
API version: v1.10.3
Plugins enabled: 1
1: Automatic Table Of Contents v1.7.2
Open Obsidian on my new Pixel 10 Fold (either tablet mode or mobile (one screen) mode. Hide soft keyboard (either by just hiding it, or by virtue of attaching a physical keyboard). The mobile toolbar is displayed at the absolute bottom of the screen, and is unresponsive.
Yes.
Should be able to tap on the mobile toolbar and have it respond.
No response from tapping on mobile toolbar.
Operating system: android 16 (Google Pixel 10 Pro Fold)
Webview version: 142.0.7444.102
Obsidian version: 1.10.6 (256)
API version: v1.10.5
Catalyst license: insider
Just a thought, but this could be related to how the Pixel 10 Fold (have not tested on Pixel 10 non-Fold) reports its size information, so that the very bottom of the screen is reported as space available to the app, when actually it's not (e.g., that's exactly where the horiontal black bar for going into select-and-search mode lies).
This is making it very hard for me to use my new phone. I was told that going back to the five-year-old navigation model with three buttons at the bottom of the screen might solve this, but I really don’t want to do that.
To clarify: do you mean the toolbar (which appears over the soft keyboard when it’s open) or the navigation bar (which only appears when the soft keyboard is closed & has back button, quick switcher, etc.)? On iOS, at least, the toolbar goes away when the soft keyboard is closed and no physical keyboard is attached.
