I hope we can get this fixed. I’m finding it close to impossible to rearrange content on Android. To select a whole section and move it without the outline option is quite hard.
This should be fixed in an upcoming release
can you drag and drop elements in file explorer? or bookmarks?
What is the output of your show debug info command
Oh i cannot drag and drop the outline, bookmarks and file or folder on android device.
Debug info
Operating system: android 12 (Xiaomi Redmi Note 9 Pro)
Obsidian version: 1.7.6 (170)
API version: v1.7.6
Catalyst license: none
Plugins installed: 5
Plugins enabled: 5
1: Commander v0.5.2
2: Dataview v0.5.67
3: Excalidraw v2.6.7
4: Templater v2.9.1
5: Calendar v1.5.10
Just happens recently when i update obsidian to 1.7.6
Hi. I also can’t drag and drop in bookmarks or file explorer.
This is an upstream chromium bug.
It will be fixed automatically when you receive an updated version of Android webview (131+).
just install anroid webview and it worked.
Now for the collapsible heading
Continue Here:
