An opinionated reflection on using folders, links, tags, and properties
This is an opinionated post on how to structure your Obsidian vault using folders, links, tags, and properties. It’s not “the right way” so please don’t get mad at me.
Disclaimer: I’m not asserting that any of this is “original”; everything you’re about to read is just me thinking out loud about how I’ve been using Obsidian lately after a lot of experimentation
Folders
Use folders for the type of files contained within them. Note that most of the below folders are for “sources” and/or “creations”, and one or two are for “areas” (personal, professional). This isn’t necessary but I include it for the sake of example, demonstrating some flexibility.
  • academic-works
  • books(non-fiction)
  • conceptual-ramblings
  • films
  • government-publications
  • industry-publications
  • journal
  • letters
  • news
  • novels
  • organizations
  • people-of-interest
  • personal
    – family budget
    – meal plans
    – personal relationships
    – rennovation plans
    – travel plans
    – other personal documents
  • poetry
  • professional
    – professional development
    ---- job applications and CVs
    – project-folder(entrepreneurial or otherwise)
    ---- meeting notes
    ---- project note
  • speeches
  • stories
  • videos
  • visual-art
Links (and files)
Use links for convenient navigation between files, visibility on “where have I used this?” or for embedding short notes and images, but not for the hope of magical serendipity, hierarchy, or relationships. Controlled use of links, i.e., controlled vocabulary is advisable compared to wanton linking.
(and files)
Also, links represent existing or potential files. A popular use for files in Obsidian is to build knowledge via the creation of MOCs, index notes, atomic notes, fleeting notes, source notes, literature notes, permanent notes, evergreen notes, and notes notes.
MOCs and Index Notes
Some people describe these as the same thing and others distinguish between them. For the purposes of this post, they are the same in that they compile information related to their given title. For example, a file called Psychology could contain all of your notes or links to notes about psychology.
This is a great approach for some. My preference, however, is not to use either unless I were taking handwritten notes and using the digital MOC/Index to keep track of them, therefore I prefer to assemble notes into MOCs/Indices for convenience only and based on the tags rather than links contained in other notes. How? Do a tag search, or add tags as aliases to your file.
  • edit 2024-03-13_16-15: I add an additional thought here that atomic notes as described below could grow into something that resembles an MOC. My purpose here is not to say that these types of larger notes are not useful, but in terms of “getting there” I prefer the approach as described below. Maybe this will change one day.
Atomic notes
I don’t describe my notes as atomic because it suggests that they should be small and static. But I do follow (loosely) the concept of an atomic note in my “knowledge notes” are named using statements rather than broad categories (MOCs, index notes). For example: “some claim about some niche aspect of some topic.” The note contains a paragraph or two about this claim following the basic concept of PEEL writing and a formatted bibliography of sources. The note is allowed to grow over time. Tags are assigned per the below section about tags, i.e., according to a controlled vocabulary.
Atomic notes are put into my “conceptual-ramblings” folder.
“Fleeting notes,” i.e., random ideas or questions that you may have spontaneously or as a result of reading something, or tagged per the below, but also receive the tag “#is/question” or #is/idea" but need not necessarily be tagged as such and can simply await further learning. Tagging this way is merely for convenience and indexing if that is important to you.
Exceptions follow…
If I have an idea for a research paper, I create a file that will be the draft of that paper and use the naming convention described in “Source notes.” I don’t bother tagging it with anything other than the topics which are relevant. If I have random ideas or questions to be addressed in that paper, I will embed or merge atomic notes as appropriate, or simply write them into this draft as if I were scribbling something down on a piece of paper.
Business idea? Create a note for it in the professional folder and dump your ideas and contacts into it. This is also true for other writing or visual art projects, such as poetry ideas, ink painting inspiration, etc. I went for a run and the muse inspired me with some beautiful rhyme so I create a new poem in my poetry folder with the one or two lines I thought of. I saw an ink painting I liked or a landscape that inspired me and would like to do my own painting of, so I create a file in the visual art folder and then replace it with a photo of said painting once I have done it, or I keep the original note to add details about the painting. As you like.
This approach is flexible enough to allow you to add tags for in-progress or whatever if you want to, but it’s not necessary unless you start 100 projects and haven’t finished any of them; arguably still unnecessary in that case.
Fleeting notes
See “Atomic notes”
Literature notes
See “Source notes”
Permanent notes
See “Atomic notes”
Evergreen notes
See “Atomic notes”
Source notes
Source NOTES are taken in Markdown files named according to the following convention: type_author_title_date (or type_author_date_title if you prefer); they are filed in the folder corresponding with their type.
Source FILES may be EPUBs, PDFs, or other file types which you may keep in Zotero or something like it. If you use Obsidian to store these files, they have the same name as the NOTES file described above and thus are sorted next to the notes files in the same folder. Images copied and pasted from a source file and embedded into a source note should also be named accordingly with a suffix such as _table-1-description or _image-of-a-unicorn.
Source notes are the notes you take while consuming some kind of content. Capture quotes and thoughts to be processed later. Processing means deciding what is valuable and deleting what is not. What is valuable because either a new “conceptual rambling/atomic note” or is added as evidence to an existing one. This means you could either treat the Source note as a kind of MOC/index containing links to atomic notes, or simply delete it when you’re done, keeping the Source file. C’est comme vous voulez.
Regarding tags in source notes, I would remove them after they have been processed.
Tags
Use tags for topics that are usually 1-3 words, such as “Psychology” or “Physics”. I prefer tags for this kind of indexing because nested tags allow for hierarchy in a way that links do not satisfactorily do. I also prefer tags because I like to keep the body of my notes clean and I also don’t really like using aliases. Folders could achieve the same hierarchy but you can’t have a file in multiple folders, as we all know.
Important here is the concept of a controlled vocabulary. I like the Library of Congress Subject Headings, after experimenting with other approaches. The only downside to following the LOC categorization is that it is incredibly thorough and can take a little bit of time to sift through to find, for example, to what “Broader Term” the term “Emotions” belongs to. But for me this is worth it to ensuring some degree of structure and coherence in my use of tags.
This matters because tag searches (not links, viewing backlinks, etc.) are my primary mode of “discovery.” What have I written about black holes? Tag search. What ideas do I have for a research paper? Tag search + path search.
Properties
Properties are for minutiae. URLs, publication date, tags if you prefer them here rather than in the body, author name, series, etc. Properties are for properties/metadata that is at a more “granular” level. You don’t have to use Properties, but it looks tidy and the devs put a lot of effort into this, so we should thank them with our participation. I don’t use links in properties.
Bonus: Plugins
I believe in future-proofing, so I only use plug-ins for things that improve my quality of life. For example:
  • Change case to change the case of my text selection
  • Hider to hide UI elements
  • Natural language dates for convenience
  • Tag wrangler for better tag management
Anything that would disrupt or determine the integrity of my notes or note-taking method is not used.
Conclusion
The goal of this approach is to simplify and consolidate. Maybe it’s only simple for me, but it feels good so I thought I should share.
Other people will probably have better ideas, but after three years I feel like this is good. It’s flexible enough to accommodate other approaches. For example, you can still create MOCs if you want to since we can add tags as aliases to notes. If you want to do everything the exact way I describe it, but add “status” and “task” metadata to notes, you can do that.
Invitation
Please critique, comment, or ask questions to your heart’s content. I plan to sign up for Obsidian Publish and I will synthesize any feedback, giving credit where credit is due for any changes to the above.
Just leaving this here because I think it’s really cool.
nice share, thanks for the insight.
I just posted an idea about something I have been calling equivalents which is a way to find instances of and relationships between little meta ideas that appear in two or three or four word ideas appearing in the middle of sentences. the same idea may be referred to by different word constellations depending on who’s referring to the idea or in what context or through what lens something is being seen.
I need something more powerful than a tag but in situations where a full note is not needed or would not create the bridges.
I feel like there should be a file in the vault or perhaps even obsidian-wide that allows per line Equivalents to be made.
it would be nice to be able to select two or three or four words and tell obsidian that this specific constellation of words represents an idea that is also known by other specific constellations of different words and represent or are related to the same idea expressed differently or by different persons or in a slightly different scope, but are a related idea.
so if you could imagine while creating a note, you could select four words, and tell obsidian that you want to create an equivalent, this would automatically surround the words with a unique markup to encapsulate those words, and obsidian would ask you to create / search for an Equivalent. when you type in a two or three or four word phrase or even a single word that is considered to be an equivalency it would add the phrase to the equivalents file on the same line as the other equivalent phrases.
imagine the chess club and the checkers club and the anti-checkers club all referred to the same idea using three different phrases. and you want to be able to find those related ideas similarly to how you find relationships through single word tags.
imagine the checkers club refers to this idea as a “zip zerb zap”, the chess club calls it a “jolly 240”, and the anti checkers club can’t stand this thing and calls it a “jackery widget woppit flummis”…
if these things are written about and included in different notes because it would make sense to do so, it would be great to have an equivalence file in the background that allows for keeping track of these and indicating their existence and relationship using hidden markup, but some sort of an unobtrusive visual clue in the note.
now “zip zerb zap” has already been written about in one note, but now you’re off in another note and you are about to mention the “jolly 240”… you would just select the words jolly 240 and through the menu, or markup, tell obsidian that jolly 240 is an Equivalent, and if it can already find the equivalent in the equivalence file it will go ahead and add the markup around it and show the visual representation that there is an equivalent or number of equivalents. or in the same way that you create links to notes, while you are creating an Equivalent, it asks you to search for the Equivalent phrase within the Equivalents.md file and automatically shows you near matches or matches, or if none are found and selected, you would press enter to create the equivalents phrase, and that equivalent phrase plus jelly 240 would be added to the same line in the Equivalents file. so you tell it that you want to create an equivalent for jolly 240, and then start typing in zip zerb zap, if zip zerb zap already exists on a line in the equivalents file, and you press enter, then obsidian will add jolly 240 to the zip zerb zap line in the equivalents file. and both of these equivalents will exist on the same line for lookup.
a few days later you find yourself copying and pasting some information into a third note from the anti-checkers club and notice the phrase jackery widget woppit flummis, and realize you would like to connect it to the other two phrases, you would just select those four words until obsidian you want to create an equivalent, or whatever we’re going to call it such as meta tag, or idea, or molecule, or whatever name expresses this concept of the best, and when obsidian asks you what you want to mark it up as an equivalent to, you can either start typing zip, or jolly, and you should see one of those word clusters showing up as an equivalent suggestion, and when you select it, it will add “jackery widget woppit flummis” to that same line in the equivalent.md file.
