An easier way to export out of obsidian
I love obsidian. However, the main issue has always been exporting stuff “out” of obsidian for other folks.
For slides, I tried advanced slides, but it is now deprecated and contains bugs such as crashing the screen.
For conversion to latex, I tried pandoc, but it has some issues such as links not being seen and not being able to convert citations.
I tried longform for combining multiple notes, but there is always extra steps that needs to be done to thereafter use pandoc.
In conclusion, there needs to be a much more straight forward way to take notes, combine them into a paper/google doc/slides, and share them to the world.
As a result, I am unable to use Obsidian for serious production level slides/research papers etc., unless I by hand copy paste and then reformat each note I had created in Obsidian which takes a lot of time in practice and somewhat defeats the purpose of using Obsidian since I could just have made a bunch of google docs.
Does anyone know a better means with which to export stuff out of Obsidian? A plugin which makes this process as seamless as possible is highly needed.
This doesn’t address combining, but you can copy from reading view to get rich text instead of markdown.
That’s neat! For now, I am resorting to copying that rich text, then pasting it into ChatGPT to give me a non markdown formatted thing, then pasting that into Google Docs. Not ideal, but gets the job done.
