Thanks for extensive Guidance!
Awesome “how to”
Thank you !!
Here’s a modification if you want to disable clicks for all custom checkboxes except for [ ] and [x].
(I haven’t extensively tested this so I’m not confident that this doesn’t break anything else)
/* Disable click in Reading View */
input[data-task]:not(input[data-task=" "], input[data-task="x"]):checked,
li[data-task]:not(li[data-task=" "], li[data-task="x"]) > input:checked,
li[data-task]:not(li[data-task=" "], li[data-task="x"]) > p > input:checked {
pointer-events: none;
/* Disable click in Editing View (Live Preview) */
label.task-list-label:has(> input[data-task]:not(input[data-task=" "], input[data-task="x"]):checked) {
Thanks a lot @holroy ![]()
Works like a charm
I see that you can download the icon pack to you own system. How can I change the -webkit-mask-image to point to a local file instead?
Sorry for replying to an old thread but I just came across this today and I wanted to get the text strike-through for a cancelled item as well.
With a bit tinkering, the below snippet worked for me:
.HyperMD-task-line[data-task="-"] {
text-decoration: var(--checklist-done-decoration);
It didn’t work for me for the minimal theme
This code works to get the text strike-through for a cancelled item
body:not(.tasks) .markdown-preview-view ul li[data-task="a"].task-list-item.is-checked,
body:not(.tasks) .markdown-source-view.mod-cm6 .HyperMD-task-line[data-task]:is([data-task="a"]),
body:not(.tasks) li[data-task="a"].task-list-item.is-checked{
color:var(--text-faint);
text-decoration:line-through solid var(--text-faint) 1px
Life saver!
Just a note on disabling the pointer events here - I applied this and it worked perfectly: except.that typing started lagging when badly when editing a task line. Something about the CSS querying seems to be make for very heavy lifting (using the minimal theme for full context).
This is awesome! Actually this right here is one of the reasons I left Notion for Obsidian. Try doing things like this with Notion. Yeah… exactly. Thanks for sharing!
Thank you so much! Works like a charm 2 years later haha
Is there a way to get checkbox outlines to be thicker? I’m experimenting with using Obsidian on a Boox Go 7, and it’s working well so far. The main initial issue is that the lines that define the shapes of the checkboxes are so thin they’re essentially invisible on the device, both in light and dark mode, and even if I pump up the font size. Thanks.
