User Story
As a user,
I want to be able to view the properties (frontmatter) of a note inserted into a canvas,
So that I can understand the note’s metadata without having to switch to editing mode.
Context: This should be possible by default or through configuration, ensuring it caters to diverse user preferences.
Acceptance Criteria
When a note is present in a canvas and is not being edited, I should be able to see the note’s properties without needing to edit it.
The system should allow me to configure whether I want to see the properties by default in the canvas or not.
The system should respect the “Properties in document” display preferences.
Properties should only be visible in the note if the “Show the entire file” display option is chosen.
This would be really useful!
You can view the properties of the currently selected note by using the properties view in the sidebar
will be implemented in v1.9.3
Is there any way to hide them? I’m on 1.9.4 and don’t want to see the properties inline on canvases. I can’t seem to find any option for that. Basically I would prefer notes in a canvas to be in ‘reading’ mode and look the same as when the note is not in the canvas.
I have a lot of little overviews with links and information that it blocks everything with the properties.
This is still an issue in 1.9.6 so I’ve hidden the properties in canvas manually with below snippet for now.
.canvas .metadata-container {
display: none !important;
Please collapse the properties in note cards by default (just like when you bring up a page preview). If one then expands the properties in a note card, the fold state should be remember though.
This CSS snippet hides Properties in note cards:
/* Hide Properties when a card is unfocused or selected */
.canvas-node {
--metadata-display-reading: none;
/* Hide Properties in edit mode */
.mod-inside-iframe {
--metadata-display-editing: none;
From Discord .
Alternatively, setting Settings > Editor > Display > Properties in document > Hidden hides Properties completely.
This is a good workaround but collapsing Properties by default would be preferable.
system
Closed
September 10, 2025, 1:36am
12
