Is it possible to allow parsing more than one tag in Projects and / or DataLoom plugins?
As far as I understand, in Projects you can only choose between basically parsing ONE tag or ONE folder with subfolders and in DataLoom you can parse some multiple metadata like lists or multiple folders - almost whatever, but not tags ![]()
It’s such a limitation! Why not to use this nice ability of adding multiple tags to metadata?
One can use Dataview as well, but it’s not as easy to manage multiple projects in it.
I searched but didn’t find an alternative yet.
Thanks for consideration!
