It would be great if the Backlinks Sidebar Pane would be Keyboard navigatable just like the File Explorer and Search Pane. (Same for the Outgoing Links Sidebar Pane)
Hey Obsidian-Team, i would also be great, if keyboard-navigation for Backlinks-Pane like the Files-Pane, Search-Pane, Tag-Pane, Bookmark-Pane, Outline-Pane.
Thanks
Same here, being able to type a lot without moving to the mouse is super helpful and being able to navigate between backlinks with only the keyboard would make that much more doable
This would be ultra useful
