Just a simple Feature request. After used Obsidian for a long time. I got many folders of many same levels. I think it will be more intuitional that if I can coloring them.
A palette with 8~24 colors will suffice.
It would be useful to be able to color-code a folder and to color-code an individual file. I sometimes use a particular file multiple times and I would like it to stand out. The ideal way to this would be by right-clicking on a folder and a file and to be able to choose from a color palette.
How about just using the same colouring as in graph view, that way you could colour both folders and files based on multiple criteria. It should be configurable however.
