All Callout Styles for Reference
The documentation of Callouts doesn’t show all styles; it just lists them. I found myself repeatedly trying out different types, so I made this reference note. I think this will be helpful to many.
MD File:
Callouts.md (338 Bytes)
Image:
I have done exactly the same thing, but thanks for sharing.
Angel
Thank you!
What theme has callouts looking like that?
The default and minimal themes have few colors so most of the callouts look the same, making them uselss.
Did you manage to find out what theme he’s using? It looks certainly good.
It’s not necessarily from a theme, from what I can see :blush:
The default callouts have been redesigned at some point in time, when Obsidian’s default theme was also refreshed :blush: .
As this topic is from 2022, this could perfectly just be the “old” callout we had with the “old” theme :smile:
Maybe this CSS snippet could help you: Callout styling - Old callouts
FYI you can also use Callout Manager to see a list of all callouts, as well as customize their icons/colors/etc, and add your own custom callouts :slight_smile:
And I also sometimes use the “List callout for quickly insert” command from Personal Assistant if I want to more quickly see a styled dropdown list of available callouts!
Thanks. It will be useful.
