I’m making this post it took me a while to find this, and thought I’d share.
The function for this is \atop
, though you can use \splitfrac{}{}
for this as well.
Example:
with \atop
it looks like this
\splitfrac{}{}
adds a small indent like this
Both can be used for more than 2 lines though you’ll have to use the functions multiple times with multiple {}
, and it can get kinda janky.
You can also use the various multiline functions to do something similar. They go around your latex like this:
$$ \begin{align}
x + y = z
\end{align} $$
You can do multiple lines as well, they are separated by two back slashes \\
$$ \begin{align}
x + y = z \\
a + b = c \\
d + e = f \\
\end{align} $$
You can also change around the point at which each line is aligned using &
symbols. This is a bit difficult to show here in the forum, but if you paste this into your vault you should see what I mean.
$$ \begin{align}
x + y = z & \\
& a + b = c \\
d + e =& f \\
\end{align} $$
\begin{align}
is also not the only function you can use here! I use a mixture, with align being the most useful, but \begin{gather}
will let you do a multi-line latex entry where every line is aligned to the centre.
If you’re interested, this page (MathJax basic tutorial and quick reference - Mathematics Meta Stack Exchange) is a pretty handy index of many of the things you can do with the math block in obsidian. It’s a bit overwhelming, so I normally just search for what I want to do rather than trying to learn everything at once. ChatGPT can also be quite helpful with this, as it can setup many of these equations for you.
I actually have a copy of that post you linked in my vault as a mathjax/latex cheatsheet lol.
But thank you for the tips!
The line break is nice. But I should have clarified that using \atop lets you stack individual segments of a formula/equation like this
${xxxxxxxx\atop xxxxxxxxx} + {yyyyyyyy\atop yyyyyyyy} = zzzzzzzzzzzzzz$
