I’m finding I’m using Obsidian more and more and only needed some simple Alfred integrations to make my life simpler and thought I’d share my basic of basics workflow.
OLog
Allows you to log data to the Daily Note in 3 different ways.
Opens the daily note from anywhere.
Searches Obsidian.
Requirements
Ensure you have Obsidian Community Plugin Advanced Obsidian URI enabled.
Environment Variables
Update your vault name in the environment variable vaultname
Commands
olog - Brings Obsidian to the front, appends current time and starts a new line with the typed text.
clog - Brings Obsidian to the front, appends current time and starts a new line with contents of the latest clipboard entry.
hotkey: +o (or choose your own) - Brings Obsidian to the front, appends current time and starts a new line with currently selected text.
os - Bring Obsidian to the front and searches with the typed text.
odn or hotkey of your choice - Brings Obsidian to the front and opens the current Daily Note.
Hope its useful to at least one other person :)
Just what the doctor ordered, thanks!
The time does not get inserted for some reason, but text/clipboard does → already happy with this!
Edit: this quick Alfred hack solved it:
you’ve just made me realise I thinkI was using another feature in Obsidian I didn’t put in requirements.
I do prefer your version though.
Thanks and I’ll update asap!!!
OK so new version out to fix the time issue and highlight where to customise the data going into Obsidian
CleanShot 2021-11-22 at 09.42.59@2x
I believe this line could be removed for clarity, unless it’s only there because I had the old version.
Cheers
Thanks. Done. :slight_smile:
Done a few new versions with some added extras. Also need to test auto-updating via oneupdater if anyone is keen?
Few more updates with some more options to get data in.
