Bug found in personal and sandbox vaults
Browse plugins
- Settings | Community Plugins | Browse
- Enter a known plugin name e.g. “dataview”
Actual result: “No results found.”
Expected result: plugins listed
Check for plugin updates
- Settings | Community Plugins | Check for updates
Expected result: progress indicator visible whilst searching for updates
Obsidian version: v1.4.14
Installer version: v1.4.13
Operating system: Darwin Kernel Version 23.0.0: Fri Sep 15 14:42:42 PDT 2023; root:xnu-10002.1.13~1/RELEASE_X86_64 23.0.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
Community theme: Things v2.0.1
Plugins installed: 100
Plugins enabled: 69
1: Dataview v0.5.59
2: Advanced Mobile Toolbar v1.8.0
3: Advanced Slides v1.20.0
4: Advanced URI v1.38.1
5: Apply Patterns v2.1.2
6: Bartender v0.5.9
7: Breadcrumbs v3.6.4
8: Collapse All v2.0.0
9: Completed Task Display v1.0.3
10: Copy Block Link v1.0.4
11: Creases v0.7.0
12: Customizable Sidebar v2.2.1
13: Dictionary v2.22.0
14: Editor Syntax Highlight v0.1.3
15: Excel to Markdown Table v0.4.0
16: Extract url content v0.12.1
17: Find and replace in selection v1.0.1
18: Find orphaned files and broken links v1.9.1
19: Flexible Pomodoro For Obsidian v0.6.0
20: Folder Note v0.7.3
21: Heatmap Calendar v0.6.0
22: Hotkey Helper v0.3.18
23: Hotkeys++ v0.2.7
24: Second Window v1.1.0
25: Indentation Guides v1.0.8
26: Key Sequence Shortcut v2.0.2
27: Kindle Highlights v1.9.2
28: Link Favicons v1.8.3
29: Metadata Extractor v1.1.0
30: MetaEdit v1.8.2
31: Natural Language Dates v0.6.1
32: Note Refactor v1.8.2
33: Obsidian Enhancing Export v1.9.1
34: obsidian markmind v1.8.2
35: Obsidian Tabs v1.0.7
36: Obsidian42 - BRAT v0.7.0
37: Obsidian42 - Text Transporter v1.0.3
38: Obsidian42 - Jump-to-Date v1.0.14
39: Omnisearch v1.17.1
40: Outliner v4.8.0
41: Ozan’s Image in Editor Plugin v2.2.4
42: Pandoc Plugin v0.4.1
43: Pane Relief v0.5.1
44: Paste URL into selection v1.7.0
45: PDF Highlights v0.0.4
46: Periodic Notes v0.0.17
47: Plugin Changelogs v1.3.0
48: Quick Switcher++ v3.3.7
49: QuickAdd v1.3.0
50: Remember cursor position v1.0.8
51: Reminder v1.1.15
52: Review v1.6.4
53: Shortcut Launcher v1.0.1
54: Sort & Permute lines v0.7.0
55: Tag Wrangler v0.5.13
56: Tasks v4.8.1
57: Templater v1.16.1
58: Workspaces Plus v0.3.3
59: Zoom v1.1.2
60: Calendar v1.5.10
61: Local images v0.14.2
62: Readwise Official v2.0.1
63: Advanced Tables v0.19.1
64: Table Generator v1.4.1
65: Annotator v0.2.10
66: Text Extractor v0.4.6
67: Meld Encrypt v2.3.2
68: Confluence Integration v5.5.2
69: Send Tasks to OmniFocus v1.0.7
