After having picked a location for my vault, can I change the location later?
I saved my vault to Dropbox and filled it with some notes. Can I change this and instead save the same vault to Google Drive?
obsidian vault is basically a folder. you can use your OS file manager to move it, but i guess better use the obsidian own move vault feature.
  • click “Open another vault” icon (usually bottom left)
  • identify your vault (some have a few, but most only have one)
  • click 3 dots icon and select “Move vault…”
  • find new location to put your vault
Thank you, efemkay, your answer solved my beginner problem.
Thanks!
