After downloading and running Obsidian-1.8.1.0.applmage my portable hard drive with over a TB of files is no longer recognizable. I cannot reconnect to it
Downloaded Linux Obsidian-1.8.1.0.applmage
Extracted to external USB hard drive
External drive then became unrecognized and after swapping USB ports, attempting to manually mount the drive , rebooting, ect… it remains unrecognized.
Hard Drive will still not mount…
System Details Report
Report details
  • Date generated: 2025-07-10 13:51:06
Hardware Information:
  • Hardware Model: ASUSTeK COMPUTER INC. VivoBook_ASUSLaptop X512DA_F512DA
  • Memory: 12.0 GiB
  • Processor: AMD Ryzen™ 3 3200U with Radeon™ Vega Mobile Gfx × 4
  • Graphics: AMD Radeon™ Vega 3 Graphics
  • Disk Capacity: 128.0 GB
Software Information:
  • Firmware Version: X512DA.317
  • OS Name: Fedora Linux 42 (Workstation Edition)
  • OS Build: (null)
  • OS Type: 64-bit
  • GNOME Version: 48
  • Windowing System: Wayland
  • Kernel Version: Linux 6.15.4-200.fc42.x86_64
The chances that Obsidian caused this are zero.
Unfortunately, it looks like you hard drive happened to fail while you where running Obsidian from it.
It took me a while to calm down enough to properly respond to this answer. As a Avionics Product Support Team lead for a major weapon system, i know that while possible… coincidences are rare… but accepting them is easy. I will attempt to determine the failure mode myself.
So thanks for the lackluster “easy button” response and please know I will not use your product ever again, and I will likely inform others to not use it either.
It’s very hard for software to cause hardware damage. This is most likely an hardware failure.
If, and it’s a big If, this is an software-caused hardware failure, you most likely need to report this problem to the Linux kernel developers.
Obsidian is a very high level software: we use electron, which uses node.js, which uses some c libraries, which call some OS-functions, which in turn use some kernel drivers to write to disk.
The hardware sanity checks should be implemented between the kernel drivers and the firmware of the harddrive.
