Advanced Slides - Presentation with molecules and reactions
Hi everyone ! I am trying to move to Advanced Slides for my day to day presentations. However, I keep struggling with the production of chemical formula and the use of the other plugins in the presentations.
For example: in Obsidian I am using chem plugin and smiles codes in order to generate molecules and reactions, one example:
```smiles
C1CCCCC1 ```
My main problem is that Advanced Slides is not rendering any of these molecules. I only fulfill to have basic reactions using $$, like:
$$\ce{H2O + CO2 → H2CO3}$$
But, I did not find any way for other types of formula with complete structures, without using a picture. It is so cool to be able to directly write code to have a chemical structures in Obsidian … If anyone has an advice, it would be wonderful.
Thanks !
Matthieu
Idk if this will help, but Advanced Slides is no longer in active development. There’s now an actively developed fork by Erin Schnabel called Slides Extended. obsidian://show-plugin?id=slides-extended
Synchronicity is right. Advanced slides is a abandoned plugin… still, It’s yet working.
By the way, I don’t have any problems to load your formulae in Advanced slides:
Maybe you’ve forgot to purge some HTML tags from your note, which hinders mathjax to compile.
Thanks Synchronicity and Jopp. Thanks for the information on advanced slides …
Yes, it is possible to show a basic equation using advanced slides or marp plugin and $$. I was looking for a way to do presentation using the chem plugin, which directly interpret a smiles code like C1CCCCC1 into a chemical structure … It would be really helpful. It is really great in basic notes !
Just another information: I am now using marp plugin which works great.
