Brief Summary: An advanced print or export to PDF option that not only exports the single active note to PDF but also identifies all internal links within the said note and includes them in an appendix within the PDF.
At present, it’s possible to export .md file notes as PDFs or use Pandoc to export to a host of other file formats. But when doing so, only the particular page the user selects is exported. All of the internalized links are “lost” in the PDF export. They may appear colorized or underlined in the PDF, but their functionality is all but gone.
It may be useful to create a plugin that retains at least some of that functionality.
For instance, imagine a user who writes an essay with multiple internalized links contained therein. The user can export the essay as a PDF and all notes referenced in the internal links are indexed and appended to the PDF. The reader of the essay then has the ability to flip through the pages and view the author’s references or internalized notes.
This may make it easier to write essays, articles, or even books within Obsidian without the use of multiple software to create a final version.
If such a feature or plugin already exists or is possible, I apologize for this redundant request and would gladly like to learn how to enable it
