Add various select commands to help iOS users
(I didn’t delete these notes, but you’ll see why)
Important Note
Popularity of a Feature Request is one of the factors we consider when we decide which new features to implement. Therefore, we strongly recommend you to search the forum with possible keywords.
If your request is very similar to an existing one, like it (:heart:) and make a meaningful comment, rather than creating a new thread. It also keeps the forum sane! If you find duplicate threads, feel free to send the moderators a message.
Feature requests for Obsidian Importer go here
Feature requests for Obsidian Web Clipper go here
Once you are done reading, please delete the above notes
Actually, the above instructions are a PERFECT example use case. Consider what I need to do to “delete the above notes” once I’m done reading while on an iOS device:
  1. double tap
  2. adjust the sliders on both right and left to accommodate the two asterisks on the right and the entire “important note” instructions on the left.
  3. While doing this, I need to drag my finger up to the top of the screen, which sadly is a recipe for unwanted behavior like scrolling to the very top of the screen in one go and losing my selection.
Basically, iOS is kinda lame sometimes.
Instead, if I had to do this in Obsidian, I could use the mobile toolbar ribbon to do the following:
  1. double tap to select a word
  2. tap “select line” command from the ribbon to select the entire line which reads “above notes (asterisk asterisk)” on my screen
  3. Tap “select all above/prior to caret” to select the entirety of the above text
  4. Delete
Specifically, I think the minimum number of “select” commands should be
  • Select current line
  • Select all to end of line (equivalent to shift + end on desktop)
  • Select all to beginning of line (equivalent to shift + home on desktop)
  • Select all to beginning of file (I think this is like shift + crtl or shift + alt + home?)
  • Select all to end of file (same)
Could add a couple more, too, like select to beginning/end of a heading, paragraph, to next image, and so on. But I would really love the 5 listed.
PLEASE! I’ve been trying to figure something out for this. I feel like having a select-all-and-copy command that I can pin for the Command Palette on mobile would be super helpful.
I’m wondering too if there’s maybe a Share feature that might have a “Copy text to clipboard” option?
