Electron allows you to set the “titleBarStyle” option to “hiddenInset” (macOS only). This allows you to have a titlebar with more space for properly sized navigation buttons.
I would like a setting (hidden or visible) which allows me to toggle between the two. Additionally, if the settings added a body class to the window, themes could target the titlebar size appropriately.
I currently have to unpack obsidian.asar, manually change the “titleBarStyle” option, and then repack the asar file every time a new Obsidian version is released.
This is how the Obsidian Titlebar currently looks like (squashed and ugly):
And this is how the Obsidian Titlebar looks like with the titleBarStyle set to “hiddenInset” in Electron and with a custom CSS snippet applied:
(Theme used is Shimmering Focus).
