Also see Properties visibility on a per-note basis? - Feature requests - Obsidian Forum.
You can use the cssclasses property to give any note a CSS class. Then target that CSS class to hide the properties in that note.
Been meaning to give the plugin a try after using this CSS Snippet for over a year now but didn’t want to install another plugin ![]()
/* Hide Properties and show on Hover */
.markdown-preview-view, .markdown-source-view { /* Both edit and preview mode */
.metadata-container {
max-height: 2.7rem;
opacity: 0.6;
overflow: hidden;
transition: max-height 250ms ease-in-out, opacity 250ms;
margin-bottom: 0;
.metadata-container:hover,
.metadata-container:focus-within {
max-height: 1000px;
opacity: 1;
transition: max-height 300ms ease-in-out, opacity 300ms;
Thanks for posting this! Does exactly what I was hoping for ![]()
Thanks for this soft open/close variant (and all your videos).
I was annoyed by properties opening every time I move the mouse from tabs to content, so I made a variant that is triggered only by hovering on the properties heading:
/* Hide Properties and show on Hover on Properties heading */
.metadata-container .metadata-content {
max-height: 0;
opacity: 0.6;
overflow: hidden;
margin-bottom: 0;
.metadata-container:has(.metadata-properties-heading:hover) .metadata-content,
.metadata-container .metadata-content:hover {
max-height: 1000px;
opacity: 1;
transition: max-height 500ms ease-in-out, opacity 500ms;
.metadata-container .metadata-properties-heading {
margin: 0;
padding-bottom: var(--size-4-3);
width: 150px;
Thanks @Mitja for the snippet!
I adjusted it a bit with more modern flexible CSS features (just removed any extra margins paddings to keep default styles), if anyone cares ![]()
body:not(.is-mobile) .mod-root .metadata-container {
interpolate-size: allow-keywords;
.metadata-content {
height: 0;
opacity: 0.6;
overflow: hidden;
transition: height 300ms ease-in-out, opacity 300ms;
&:hover .metadata-content {
height: auto;
opacity: 1;
Thanks @Kageetai.
FWIW, here is the modernized version of my variant - properties open only by hovering over the properties heading.
.metadata-content {
height: 0;
opacity: 0.6;
overflow: hidden;
&:has(.metadata-properties-heading:hover) .metadata-content,
height: auto;
opacity: 1;
margin-bottom: 0;
width: 10rem;
This CSS snippet worked like a charm; tyvm!
