I’m trying to set predefined values for property tipe “List”. As I usually used to do in Notion (i.e. I selected a property as “multiselect” and then I could set all the possible values for that property).
The issue I’m seeing, is that I couldn’t set predefined values for this property, but I have to choose between the already created values for it. This means I couldn’t set all the possible selectable values at once (to choose afterwards which ones correspond to the new notes), but I have to assign them as I create the notes.
For example, “NoteType” is a list type property here, and I want to set all the possible values this property could have
Is that possible without setting the values in prior notes?. Since I want to think and set all the possibles values at once.
I’ve tried to search for options to set predefined values for list type properties on the “All properties” menu, but I don’t see anything related to this.
May be someone of you know a workaround to do so, I would like to know which if so. May be something like a template of possible list values for certain properties.
