Add plugin in right side bar/right pane
I installed tasks plugin and it would by default positioned in right side bar/right pane.
By accident I closed it (cmd+w). Other way to close it is right click on icon in right pane → close.
I can not find a way to get it back. I search so many posts and google how do I get all the tasks listed using “Tasks” plugin in right pane.
Few post says drag it to right pane but I could not find what to drag. I can only open a note in a tab which I can drag but how do I even open plugin in a tab to drag it to right pane.
I think that Im missing something fundamental here.
What was positioned in the right pane? I don’t know of any default Tasks windows that can be docked.
Do you have a picture of it somewhere?
Screenshot 2023-07-26 at 11.15.13 AM
Here is the screenshot of reminder plugin on the right side bar. I used to have same for Todo too.
Sorry I just realized I was saying Tasksk plugin but it is actually obsidian-plugin-todo - Obsidian Hub - Obsidian Publish
I uninstalled it and reinstalled and I get this in the pane back but I think question still stand how do I get it in future if I close it again. Attaching picture
Screenshot 2023-07-26 at 11.19.01 AM
I should not be uninstalling and reinstalling back.
I don’t use this plugin, but you can probably launch it from the command palette (CMD P) → todo.
