Have you enabled inline queries within code blocks in your dataview settings? That could possibly explain some of this behavior…
Related to your original request, I’m thinking that you can’t return something from dataview and expect dataview to run again on that output (if that makes sense). It’s like a variant over the theme which came first; the chicken or the egg? I think you need to either use someone like app.fileManager.processFrontMatter(), or trigger a call to a plugin like the metadata which have functions for changing fields.
Evaluation Error: TypeError: Cannot read properties of undefined (reading 'extension')
at e.<anonymous> (app://obsidian.md/app.js:1:1491314)
at app://obsidian.md/app.js:1:237027
at Object.next (app://obsidian.md/app.js:1:237132)
at app://obsidian.md/app.js:1:236048
at new Promise (<anonymous>)
at v (app://obsidian.md/app.js:1:235793)
at e.processFrontMatter (app://obsidian.md/app.js:1:1491216)
at eval (eval at <anonymous> (plugin:dataview), <anonymous>:1:76)
at eval (eval at <anonymous> (plugin:dataview), <anonymous>:4:4)
at DataviewInlineApi.eval (plugin:dataview:18638:16)
at evalInContext (plugin:dataview:18639:7)
at asyncEvalInContext (plugin:dataview:18646:16)
at DataviewJSRenderer.render (plugin:dataview:18670:19)
at DataviewRefreshableRenderer.maybeRefresh (plugin:dataview:18254:22)
at HTMLDivElement.r (app://obsidian.md/enhance.js:1:11895)
There are indeed multiple references with various context to be used slightly different depending on whether you’re using a DQL query or dataviewjs query:
a link – Which has the properties of path, display, etc
a page reference - Which is used to access the properties of a given page (and related file information)
a TFile reference – Which is more of an internal file reference
In DQL you normally use the link and page references, and they sometimes even coexists to make it easier for the end user. Within dataviewjs, they don’t coexists and you need to be careful whichever variant you’re using. You can however access both variants with proper code. Lastly the TFile can be found as a return option from various calls, and I’ve so far used the following method (given a file path to the page I want to access):
See Open a file in callback - #2 by holroy for slightly more information on these two methods. In the code above file refers to some file link, like in a link context, so that the .path is available providing the file name (with path) of that link.
Hopefully this explains some more about the TFile thingy, and how to access is from dataviewjs (or similar). The app.workspace.getActiveFile is another way, with its caveats, to get to a relevant TFile in your context.
Thank you so much for your help! This is what I ended up with and I’m very happy with the results. This code adds together the values and lists of the given property names and adds them to the frontmatter of one file.
