Execute in console this script
app.workspace.activeLeaf.view.sourceMode.cmEditor.setOption('extraKeys', {
'Ctrl-Enter': function(cm) {
const doc = cm.doc
const lineNum = doc.getCursor().line
const lineContent = doc.getLine(lineNum)
const isEmptyTodo = string => /^-\s\[\s\]/.test(string)
const isCheckedTodo = string => /^-\s\[x\]/.test(string)
const check = () => doc.replaceRange('x', {line: lineNum, ch: 3}, {line: lineNum, ch: 4})
const uncheck = () => doc.replaceRange(' ', {line: lineNum, ch: 3}, {line: lineNum, ch: 4})
if (isEmptyTodo(lineContent)) {
console.log('empty')
check()
return true
if (isCheckedTodo(lineContent)) {
console.log('checked')
uncheck()
return true
console.log('not todo')
return false
@Silver I think something like this could be added into release with no problem as that’s a usual CodeMirror binding, right?
Snippets below will add a global keyMap (previous was only for current pane)
When Vim disabled:
CodeMirror.keyMap.default= {...CodeMirror.keyMap.default, ...{
const doc = cm.doc
check()
return true
uncheck()
return true
return false
When Vim enabled:
CodeMirror.keyMap.vim = {...CodeMirror.keyMap.default, ...{
const doc = cm.doc
check()
return true
uncheck()
return true
return false
You can run both snippets to have functionality in both modes.
nhdhung
3
Thanks a lot for this @mrjackphil
