Add group option to keep "card" and/or "note" together in CANVAS
canvas
The canvas news is really fantastic! thank you
Inside CANVAS, It could be really confortable to group various items (note, card..) to move them or controle them easily later without all the time the need to re-select them.
The solution could be to add an option once several items are selected (“Group the selection” )to group them.
Ctrl G to group several objects as one (and ungroup) and the possibility to put several cards in a frame (a bigger card) to make 1 object with it.
Will be implemented 1.1.4
So Niiiice ! thank you !
