add a fallback font for unicode characters, and if it’s not possible, use mark tags to use the font.
i tried using the font (nasin-nanpa) as a fallback font, but since i can’t install the font on my phone, it doesn’t appear as an option in the dropdown menu. this worked on my laptop, which i imported the vault im using from, but the text doesn’t render.
i have tried using the custom font plugin, but when i select the font everything (menus, normal text etc) turns into the font. so i selected the multiple fonts option and slightly modified the provided css (adding the class .nasin-nanpa to show the font) which makes the normal text appear in the normal font, but i tried to use the mark tag to show the font but it doesn’t work and it just turns the background of the lined squares into yellow.
