Add commands to ribbon menu?
It would be nice to be able to 1-Click commands from the ribbon menu but I can’t figure out a way to do it, nor find a plugin which enables it
Poring through Obsidian’s settings and the Community Plugin hub for something that can do this
I’ve not used it myself, but I hear that this should be doable using the Commander plugin. So try that.
Lately, I’ve been running out of key combinations for Templater snippet, so I put some icons on the status bar (more space for me there).
Also, if you have the Editor Toolbar plugin installed, you can put commands on the toolbar even in sub-menus, which is pretty convenient.
