Add command for embedding base as a code block instead of creating a base file for it.
A lot of times a want to include a niche base into a note without cluttering my files with additional base file, when there’s option to create a base using code block - making it a command with a shortcut
Make a command Embed a base as a code block that inserts code block with unset base, and possibly a new line so it immediately renders as a base:
```base
or possibly some base with parameters (example - notes made today) as this base lists all notes in vault and could be very long
Inserting premade template
