Absolute link path has higher precedence than relative path
Consider vault with the following files
A.md
Absolute path resolved A
Folder/A.md
Relative path resolved A
Folder/B.md
Wikilink [[A]] resolves to the root `A.md` rather than to the relative one `Folder/A.md`
Same issue with the markdown link [A](A.md)
Y
Relative Folder/A.md should be taken precedence when resolving absolute vs relative path collisions.
Root A.md is resolved as a link.
Obsidian version: v1.4.16
Installer version: v1.4.13
Operating system: Windows 10 Pro 10.0.22621
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
There exists a workaround to explicitly specify the type of the links
[[/A|A]] and [A](/A.md) resolve as absolute link path
[[./A|A]] and [A](./A.md) resolve as relative link path
However such workaround has its own issues, and it’s better for it to be addressed on the Obsidian dev level
This is not a bug. it’s intentional. Otherwise, where [[A]] points to depends on which file it is contained. We don’t want that. We want [[A]] to point to the same note across the vault.
In other words, we don’t want [[A]] to point to one note if it is contained in Folder1/Note1.md and to another note if it contained in Folder2/Note2.md.
No, a link to [[A]] in that note still resolves to A.md in the root.
What if we consider this not as a bug but as a feature request to add a configuration setting? By its nature markdown built to use relative paths, so while Obsidian team prefers the absolute paths by default, I think it would be very handy to give a setting to switch to relative-first approach. Or even disabling absolute path resolution completely
You can open a FR about this if you want. I am unsure how likely it is to happen.
Regarding relative paths, this is more likely to happen:
My FR
@WhiteNoise I found a new argument explaining why this behavior is indeed a bug
If you run the following code
app.fileManager.generateMarkdownLink(app.vault.getAbstractFileByPath('Folder/A.md'), 'Folder/B.md')
you get
[A](A.md)
According to the API documentation, generateMarkdownLink generates a markdown link to the destination Folder/A.md from the source Folder/B.md
However as described in the previous comment, the link leads to the root A.md instead
If we would want to get a link to the root A.md
app.fileManager.generateMarkdownLink(app.vault.getAbstractFileByPath('A.md'), 'Folder/B.md')
we get
[A](../A.md)
which is a valid link to the root A.md
I think, those examples prove that at least the API documentation and the Obsidian link resolution logic are inconsistent.
Yes, this is a bug of the link generator/suggestion, not the link resolver.
I’ll write a bug report about it. Thanks!
I am sorry, but I disagree. Such links work properly in every other markdown editor. And only Obsidian treats them in a non-standard way.
Obsidian team claims
Obsidian strives for maximum capability without breaking any existing formats. As a result, we use a combination of flavors of Markdown.
Therefore, such behavior is a violation of the declared principle, and should be considered as a bug.
I understand the undesired effect of changing the behavior, that’s why I suggested a more configurable way in my FR
ok, you opened your FR for that.
