Ability to split vertically above or below; ability to split horizontally left or right
When using the split vertically or split horizontally feature, I’d prefer to be able to control which way (i.e., above or below; and left or right).
At present, it defaults to below and right.
I think we should have a separate toggle (so split to the right; split to the left; split above; split below).
OR
have a default setting so vertically always means one thing and horizontally always means another.
I prefer the first option as the 2nd is not flexible enough. However, if this is implemented, then the 2nd option would not be so bad:
It’s cumbersome to have to drag the pin to where you want it after you have split it horizontally or vertically, esp. when you already have a lot of panes. It takes your hands away from the keyboard and disrupts your reading or writing/productivity.
A post was merged into an existing topic: Add option to customize default direction of split for new pane
