Request: The ability to pin the Backlinks view. (Alternatively, to have the Backlinks displayed as an integrated part of the note’s body.)
Use case: Sometimes I want to quickly open all the backlinked notes using shift-click. Or I want to browse through a series of notes on a topic.
In Obsidian, if you click or ctrl-click on a Backlink, it opens that note, and then it changes the Backlinks to the newly opened note. So it is impossible to quickly open all of the backlinks to a given note. Even if you have a note Pinned, the Backlink view changes, and there doesn’t seem to be a way to lock or pin that view.
In Roam - as an example - backlinks are an integrated part of the note, at the bottom of the note. This allows you to do something like this:
- Open a note
- See 5 backlinks
- Shift click on each backlink to open each of them in the sidebar as a queue or comparison.
Current Workaround
I do realize that I can do this by using the Search pane, and searching for the “[[Backlink]]”.
