We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
To use obsidian in any corporate environment we need the ability to disable sync and prevent users from enabling. Otherwise, obsidian will not be allowed by most InfoSec teams
Enterprise version. If you make the cost reasonably low, you’ll get a lot of customers. The InfoSec team should be able to configure whether sync is enabled, and also have the ability to enable specific community plugins (all disabled by default)
I see many, many requests for the ability to block the sync feature to allow Obsidian to be used in a corporate environment (and pay for it).
Can we raise the priority of providing a solution that will work for enterprises and satisfy their Info Sec departments? I’d be happy to trial at my company and be happy to work with you on a solution that gets past our Info Sec team.
